using 2 Plusnet hub ones.
dimillar
Interested
sorry i dont know all the correct terms. I've got 2 Plusnet hub one's and want to know if it's possible to connect them together so that I've got ethernet connections and better WiFi signal covering my whole place. I've got one a stupidly long ethernet cable I use to connect them any distance apart in my place if needed. just want to be able to have one hub in my sitting room and one in my pc/games room at the other end of my home.
3 REPLIES 3
Marketman
Re: using 2 Plusnet hub ones.
I use a BT Home Hub 5 with my Hub One (which is very similar to the Hub 1) in exactly that way.  If you search the internet for using the HH5 as a repeater or wireless extender and follow the instructions (I followed a YouTube video), the only thing that is different with mine is the BT account name which needs to be  PlusNet within the Hub.
Marketman
.....should have also added that lights keep flashing on the Home Hub 5 (can't connect to internet - it is connected to Hub One's internet so no direct connection), but it still works fine.
PeterBirt
I setup mine in this way. I posted a guide at the link below.
https://community.plus.net/t5/My-Router/Using-a-2nd-Plusnet-Hub1-as-a-Wireless-Access-point/td-p/138...
Hope it helps
