using 2 Plusnet hub ones.
- My Router
- Re: using 2 Plusnet hub ones.
07-11-2016 12:24 PM
07-11-2016 1:56 PM
I use a BT Home Hub 5 with my Hub One (which is very similar to the Hub 1) in exactly that way. If you search the internet for using the HH5 as a repeater or wireless extender and follow the instructions (I followed a YouTube video), the only thing that is different with mine is the BT account name which needs to be PlusNet within the Hub.
07-11-2016 2:10 PM
.....should have also added that lights keep flashing on the Home Hub 5 (can't connect to internet - it is connected to Hub One's internet so no direct connection), but it still works fine.
11-12-2016 10:34 PM
I setup mine in this way. I posted a guide at the link below.
Hope it helps
- My Router
