uploading vids and screenshots
tmxman
Im using xbox on my windown 10 laptop and im using game DVR ive saved screenshots and clips and when i try to upload them its saying it may be a server problem ive been through Microsoft and xbox and everything is fine and i was told its the Nat Type im on. i need to change it to open to allow uploading so can anyone tell me how to change the NAT Type from moderate to OPEN Pls for my plusnet HUB ONE
2 REPLIES 2
Mav
Fixes: 507
Re: uploading vids and screenshots
Moderator's note:
This thread has been movee from Fibre Broadband to My Router.
Forum Moderator and Customer
SteveA
It looks like you change it on your XBox
https://www.techadvisor.co.uk/how-to/network-wifi/how-change-your-nat-type-on-xbox-one-3657187/
 You may also find setting up Port Forwarding on your router helps. I know the Hub 1 has some predefined rules for XBConnect and XBoxLive.
