unknown device lan1
bdh50
unknown device lan1
Plusnet Hub One: Home network Devices shows :-
Unknown
00:00:00:00:00:00
192.168.1.67
Not connecte
 Nothing connected to the lan port and I cannot delete it. Any suggestions appreciated
2 REPLIES 2
Aspiring Hero
Fixes: 73
Re: unknown device lan1
Hi @bdh50 welcome to the forums.
I've seen this issue a couple of times with a Hub One, I found a power cycle cleared this oddity. As to the cause, not sure.
I had a few issues with DHCP on my Hub One so I replaced it with a TP-Link modem/router.
Hope this helps
Dan
bdh50
Thanks Dan_the_Van, Rebooted modem when I first noticed it but still there. Next day noticed speed was really low so rebooted again , speed back up and issue cleared. Thanks again for your response.
