the router ~ can it do cat5 and no wireless? ~ I don't want wireless.
- My Router
- Re: the router ~ can it do cat5 and no wireless? ~...
31-07-2021 11:47 PM
the router I'd get with that cheapest deal,
what brand/model is it?
I don't want wireless. so, can it be switched off, and used wired only?
Re: the router ~ can it do cat5 and no wireless? ~ I don't want wireless.
01-08-2021 9:31 AM - edited 01-08-2021 9:32 AM
@siljrath Welcome to the forum
Its a Sagem 2704n. It has four 10/100 Mbps Ethernet ports compatible with CAT 5 cables. You can switch the wireless off or just leave it on.
01-08-2021 10:08 AM
01-08-2021 10:44 AM
If it’s a Hub one then it’s a BT Home Hub 5a with modified firmware. These have dual band wireless and four 1000/100/10 Mbps Ethernet ports suitable for your CAT 5 cables. Again you can switch off either one or both Wireless bands should you choose to do so
02-08-2021 11:37 AM
@dvorak wrote:
it may be a Hub One - I think some new ADSL customers are getting them.
Aye, we retired the Hub Zero on the 22nd June. We've been sending Hub Ones for ADSL & Fibre connections since then.
- My Router
