td-w9970 setup
smashraf
td-w9970 setup
have tried auto and manual but not getting any where as i need to check a blocked site see if it is ok
the plusnet modem is working fine no problem but the site is blocked for some reason also have tried the safe guard and all those blocked categories but no luck so far.
may be should tell you what happened.
last month downloaded opera web browser to try vpn did notice that it reset the plusnet modem few times so did not like it
uninstalled it but since then no download from yahoo financial site have tried resetting the plusnet modem but nothing so bought this one but now can not set it.
i need that download so some one must have an idea would be greatfull.
5 REPLIES 5
bill888
Aspiring Champion
Fixes: 34
Re: td-w9970 setup
When you used Quick Setup in TD-W9970, did you enter your full plusnet username and password ?
The format of the username is typically:      username@plusdsl.net
TD-W9970 emulator
http://www.tp-link.gr/resources/simulator/W9970V1_Emulator/index.htm
smashraf
Re: td-w9970 setup
no,in user name i entered the name that is on the card with the plusnet modem typically it starts with plusnet
is that where i went wrong ? well no harm in trying will try your way.
SpendLessTime
Aspiring Hero
Fixes: 86
Re: td-w9970 setup
@smashraf
Welcome to the forums.
The details you need to set up your connection to Plusnet are given at https://www.plus.net/help/broadband/broadband-connection-settings/
smashraf
Re: td-w9970 setup
hi
thanks for putting me on the right track and now it is on line.
thanks once again
smashraf
Re: td-w9970 setup
thanks for your reply bill888 was good enough to put me on the right track so sorted now.
