synology plusnet hub 1 firewall port
- My Router
- Re: synology plusnet hub 1 firewall port
14-08-2020 12:27 PM
Folks
I have a synology DS720+ which has application called Drive (Private cloud)
Fromt thesynology site they state the application needs port 6690 to be open
https://www.synology.com/en-global/knowledgebase/DSM/tutorial/Network/What_network_ports_are_used_by...
Therefore from the firewall (Advanced) I have added
TCP 6690 6690
However using the External IP address as given by the plusnet router
I can not connect to the Cloud Drive Storage
Event Log
11:06:52, 14 Aug. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.84]:6690 <--> [999.143.49.135]:6690 - - - [999.143.49.135]:1024 ESTABLISHED/ESTABLISHED local_dev NAPT)
NOTE 999 is not the real external IP address , just changed in case
If I use the internal IP (Same WiFi) then I can connect
Using Synology Quickconnect does work , but would prefer not to use this as Quickconnect is soft blocked by my company.
Any thoughts.
Matt
17-08-2020 6:09 PM
Hi @emjga
Thanks for getting in touch.Can you please confirm if you have tried to do same thing after turning broadband firewall off and what was result of this? You should be able to do it here https://www.plus.net/member-centre/broadband/firewall
You can find m ore information about port forwarding here
- My Router
