static ip for my rasp pi?
- My Router
- static ip for my rasp pi?
19-05-2018 7:40 AM
I am trying to set up a static IP for my rasp pi.
I used the expert user page or the router, Advanced Setup, LAN and allocating an ip address under:
Static IP Lease List: (A maximum 32 entries can be configured)
The DCHPserver was enabled, and had the addresses 192.168.1.1 - 192.168.1.253
I set up the rasp pi to be allocated the ip address 192.168.1.8
That seemed to work for a week or two. Now it no longer does, my rasp pi now appears with an ip address allocated by dhcp.
(BTW, on the home page of the router where there is a list of connected devices, sometimes there are no connected devices listed, or I have some devices that are clearly connected but don't show up on that list. Is my router broken?)
I have tried different ip addresses for my rasp pi, both within and outside of the DHCP server range. I've tried setting the DHCP range to 192.168.1.1 - 192.168.1.199 and putting the rasp pi on 192.168.1.200 - like that, the rasp pi doesn't show up at all.
I'm stumped. This should be simple shouldn't it? Is my router broken or am I missing something fundamental?
Thanks,
Re: static ip for my rasp pi?
19-05-2018 7:46 AM
I should have added I have a Hub Zero router.
19-05-2018 1:26 PM
on
19-05-2018
1:50 PM
- last edited on
19-05-2018
9:24 PM
by
Mav
Thanks for your response. The operating system I have on the pi is Googles IOT, and it isn't at all obvious how to set up a static ip address in the device itself.
Googling it, I just come across suggestions to set teh ip address on the router using the MAC address, which seems logical to me. (https://stackoverflow.com/questions/42061723/how-to-set-a-static-ip-in-android-things-running-on-ras...)
Why am I unable to reserve an ip address on the router for the pi? Is it incapable of this? Is it broken? Am I doing something wrong? I have an old TP_link moden, an N600. Perhaps I could use this in place of Plusnet's router? (I was able to assign ip addresses with that with my old ISP).
This information reflects the current status of your 'WAN' connection.
Line Rate - Upstream (Kbps): | 1263 |
Line Rate - Downstream (Kbps): | 20059 |
ShowtimeStart (seconds) | 21223 |
LAN IPv4 Address: | 192.168.1.254 |
WAN IPv4 Address: | [Removed] |
Default Gateway: | 172.16.14.52 |
Primary DNS Server: | 213.120.234.42 |
Secondary DNS Server: | 213.120.234.38 |
LAN IPv6 ULA Address: | |
Default IPv6 Gateway: | |
Primary IPv6 DNS Server: | |
Secondary IPv6 DNS Server: | |
Date/Time: | Sat May 19 13:36:16 2018 |
Moderator's note by Mike (Mav): Personal information removed from a public forum.
19-05-2018 1:53 PM
19-05-2018 3:06 PM
My project couldn't wait for a firmware update. I've fired up my old TP-Link modem, and it has far more options available. All sorted now, so thanks.
