set-up for RT-AC68U?
throwawayforum
I am switching to Plusnet from BT tomorrow - I want to keep using my RT-AC68u (which is plugged into a HG612).
What are the ideal settings?
3 REPLIES 3
SpendLessTime
Fixes: 86
Re: set-up for RT-AC68U?
Welcome to the forums @throwawayforum
Just change the username and password as everything else will be the same as BT.
(Indeed many Plusnet users use the BT Homehub devices which are locked down and only need a username/password change to work)
The Plusnet help for connection settings is here at https://www.plus.net/help/broadband/broadband-connection-settings/
mharvo
Using the Asus GUI just enter plusnet user name and password... set up wireless.... if you need Plusnet IPTV BT Sport channels go to LAN >IPTV (two settings needed) and select microsoft and enable IGMP Proxy
Check in WAN that Enable VPN + DHCP Connection is enabled.
Your good to go to view the channels...
Mine is working fine with latest firmware 384
throwawayforum
Thanks - I actually sold the RT-AC68U and have swapped to the Orbi RBR50 which I've been very happy with - plug and forget.
