router technicolor tg582n port forwarding configuration does not work
- My Router
- router technicolor tg582n port forwarding configur...
on 16-07-2017 1:40 PM - last edited on 16-07-2017 9:53 PM by Mav
Hi all,
I am configuring my router technicolor tg582n for port forwarding.
As I have to reach remotely my PCs I should forward the port UDP 9 to the broadcast address 192.168.1.255.
I found several guides in the web but not regarding the forwarding to broadcast address...
As it does not work, may someone please tell me where the following steps are wrong?
- Click Create a new game or application under the heading Pick a task...
- In the box labelled "Name" type "Wake on LAN”.
- Click Manual Entry of Port Maps
- Click Next
- Select the protocol UDP from the drop-down menu under the heading Protocol.
- Fill in the start port nr (9) and the end port nr (9)
- Leave the other boxes empty and click Add.
- Click Apply.
- Click on the option to Assign a game or application to a local network device
- Locate:"Wake on LAN” from the drop-down menu under the heading Game or Application
- In the drop-down menu under the heading Device select the name of the device you need to forward ports to.
- Select “user-defined…”
- Type the broadcast network address: 192.168.1.255
- Click Add.
The router should now set up with the port forwarding configuration
Moderator's note by Mike (Mav): Post released from Spam Filter
Re: router technicolor tg582n port forwarding configuration does not work
20-07-2017 7:49 PM
If you're trying to do "wake on LAN from the internet", then the following link shows how to do that with a Technicolor router.
Sorry it's from a archive site, the original is no longer available.
https://web.archive.org/web/20160728221606/http://npr.me.uk:80/wol.html
21-07-2017 10:11 AM
many many many thanks npr!!!
i will try soon these steps
have a nice day!
24-07-2017 9:29 AM - edited 24-07-2017 9:30 AM
not yet tried, seen that the router will require a reboot, so i prefer to be onsite to do that test...
but, in the meanwhile, i have a doubt: do you think it is possible to extend this wol to the entire lan instead of a single pc?
24-07-2017 12:48 PM
Never tried sending wol to the whole lan, so don't know if it works with the technicolor. I do know the method I previously posted does work, you could extend that to more devices by just using a different port and ARP entry for each device.
You could experiment with sending to the entire lan by:
Port forwarding to 192.168.1.10 (or any unused IP) and then editing the arp table for that IP:
IP = 192.168.1.10 hwaddr= ff:ff:ff:ff:ff:ff
- My Router
