Hi
i currently use a netgear router but was reading up on using my old plusnet router as an access point. First i thought id fire it up and see what version it was running etc before making any major changes i found the power supply and plugged it in. At this point no Ethernet connected but i am a bit bemused as i still thought the wireless side would work and i would be able to access it wirelessly to check the settings. No wireless which i find bizarre because if i pull the Ethernet cable out of my net gear router i can access as admin the internal settings menu even though its not connected to the internet am i doing something wrong surely it doesn't have to be connected to the internet to allow the wireless part of the router to work bit stumped. I then connected it to the internet and low and behold the wireless worked iv made the changes to allow it to become an access point plugged it into my netgear router no wireless or i should say no indicated wireless any help appreciated im going off of an old post to allow me to be able to do this
https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Unlocking-the-potential-of-Sagemcom-27...
Ben
