router hissing
- My Router
- router hissing
router hissing
30-01-2019 10:44 AM
Anyone else have a problem with the router hissing and speed dropping? I'm on my 4th router now and having the same issue again but now pn want to charge me for a new one. bit of a pain in the [-Censored-]
Re: router hissing
30-01-2019 11:32 AM
If its a high pitched noise then it is probably caused by small electrical components vibrating on the circuit board. To me it sounds a bit like a cricket or cicada on a summer's day.
The noise is perfectly normal and nothing to worry about and shouldn't affect the operation of the router.
Component manufacturer's explanation is here : https://www.murata.com/en-eu/support/faqs/products/capacitor/mlcc/char/0020
Re: router hissing
30-01-2019 11:57 AM
Moderators Note
This topic has been moved from Chat to My Router
Re: router hissing
30-01-2019 1:50 PM
Hi @Spencegovan,
I'm sorry that your router is hissing and for any inconvenience caused. It might be worth disabling the 5GHz wireless band as this normally stops the noise - however, this will mean that your devices will all connect via the 2.4GHz band.
To disable the 5GHz band you would need to take the following steps:
1) To connect to your Hub One, you will need to open a browser and go to 192.168.1.254 If you have any issues doing this via Wireless, we recommend trying to do it via Ethernet cable instead.
2) You should come to a page with information about your connection, click 'Advanced Settings' at the top and it will ask you to sign in with a Password. This is located on the back of your router under 'Admin Password'
3) Select the option for 'Wireless' followed by '5 GHz Wireless'
4) Change 'Wireless network enable' to 'no' and then click apply
Re: router hissing
31-01-2019 9:24 AM
Re: router hissing
31-01-2019 9:44 AM
The noise is a known problem. The manufacturer is digging their heels in and saying the noise is within accwptable limits. My advice is in this post https://community.plus.net/t5/Fibre-Broadband/Hub-One-Buzzing-Fizzing-Noise/m-p/1608568#M89149
