replacing sagemcom router
- My Router
- replacing sagemcom router
20-05-2020 9:35 AM
Re: replacing sagemcom router
21-05-2020 1:54 AM
The USP (Unique Selling Point) for all these expensive routers is their claimed wireless abilities.
The Hub 1 router is very inflexible, but you might find that if all you need is better router features that something off of eBay is sufficient (and hugely cheaper).
21-05-2020 7:26 AM
21-05-2020 8:21 AM
Moderators Note
This topic has been moved from Tech Help to My Router
21-05-2020 12:19 PM
What features do you require?
If you're a serious gamer then by far the best solution is to connect your device to the hub via an Ethernet cable, in which case a Plusnet hub will do all that you want.
