replacing sagemcom router
scousepcgamer
Im thinking replacing my Plusnet router with either a Netgear AC2600 Nighthawk® X4S VDSL/ADSL Modem Router on it's own or a Netgear Broadband High-Speed DSL Modem DM200 & Netgear NIGHTHAWK PRO GAMING XR700.
Anyone have any better ideas.
4 REPLIES 4
VileReynard
Fixes: 20
Re: replacing sagemcom router
The USP (Unique Selling Point) for all these expensive routers is their claimed wireless abilities.
The Hub 1 router is very inflexible, but you might find that if all you need is better router features that something off of eBay is sufficient (and hugely cheaper).
scousepcgamer
Any suggestions for a router you would go for?
Fixes: 1,483
Moderators Note
This topic has been moved from Tech Help to My Router
Fixes: 419
@scousepcgamer
What features do you require?
If you're a serious gamer then by far the best solution is to connect your device to the hub via an Ethernet cable, in which case a Plusnet hub will do all that you want.
