remote desktop to two pc's
- My Router
- remote desktop to two pc's
15-10-2016 6:04 PM - edited 15-10-2016 6:04 PM
I'm new to plusnet, and using their Hub One router.
In the advanced config I can set up a remote desktop under port forwarding to a pc and this works fine.
My issue is I have two pc's on my home network that I want remote access to.
With my previous broadband and more techy router I could just add port rules to forward to each pc for remote desktop, eg 3389 to one pc, 3390 to the other etc.
With the hub one I cannot see how I can do this - any suggestions ?
Re: remote desktop to two pc's
15-10-2016 7:10 PM - edited 15-10-2016 7:14 PM
Advanced settings->Firewall->Port forwarding->Manage games and applications
Create the rules there.
15-10-2016 8:36 PM
thanks Browni,
have found those settings and think set-up - see attached:
but only works on the original microsoft remote desktop one - I have tried swapping the devices and whichever pc is assigned to the ms remote works - neither work to my remote 2 one ??
15-10-2016 8:45 PM
Is anything listening on port 3390?
15-10-2016 9:05 PM
a restart of pc's and router has got it working - I think it was probably the pc that needed a restart after I changed the listening port in the registry.
thanks for your help, was thinking I'd have to get a more expensive router as I used to use one of the billion ones which was really good but doesn't work with fibre of course.
15-10-2016 9:20 PM
15-10-2016 11:57 PM
You could have translated port 3390 on the WAN interface to port 3389 on the LAN interface.
15-10-2016 11:59 PM
That was going to be my next suggestion
16-10-2016 2:22 PM
thanks for all your help, translating the ports would have been a great idea but as it's working now going to leave it be !
got wake on lan working too so well pleased with things now.
