port fowarding
rod-router
port fowarding
Can someone help?
See my attachment, both portchecker and yougetsignal both say the port is closed, why?
In the 'show ip address' column I have selected my internal device which needs to accept connections
Any help would be greatly appreciated
14 REPLIES 14
Champnet
Fixes: 21
Re: port fowarding
Is there any device in your network listening for activity on thoses ports ?
Re: port fowarding
@rod-router
There is nothing wrong with the port forward rule you have setup
On the Hub Two looking in >Technical Log >Event Log do you see for the time you tested the connection using portchecker or yougetsignal these entries? (The 192.168.10.220 will be your listening device)
19:04:39, 02 Sep. FWL Port Forward Server(192.168.10.220) TCP 5006 accepted a new connection from 85.255.232.96
19:04:38, 02 Sep. FWL Port Forward Server(192.168.10.220) TCP 5006 accepted a new connection from 85.255.232.96
These are examples of a port forward rule accepting a connection.
You can not test a UDP port connection with those sites
You need the device the port forward rule points to application listening  (running) for inbound connections for a tester to confirm connection, is this the case?
EDIT: new connection from will be the IP Address of the tester
rod-router
Re: port fowarding
Yes, I have a NAS device listening for port 5006 which I have given it a specific ip address within the ip range for the router
Yes. In the log there is an entry which says "FWL Port Forward Server(my device ip address) TCP 5006 accepted a new connection from 45.33.50.110
But portchecker still reports 5006 is closed? and I still cannot connect to my NAS outside of the internal network
Re: port fowarding
Are you able to connect locally? I'm expecting you can.
Is the NAS default gateway IP Address correct, should be the Hub Two.
Some NAS drives have a  firewall which needs setting up for outside connections to be allowed
Champnet
Fixes: 21
Re: port fowarding
@rod-router  Is this a Synology box ?
Being nosey can/will you say what's opening port 9308.
Re: port fowarding
@Champnet
that port is UPnP created rule
Champnet
Fixes: 21
Re: port fowarding
@Dan_the_Van  If it's P&P then an application has opened it.
Re: port fowarding
Yes I knew about UPnP but not P&P
Late now, I'm not about tomorrow so I'll leave this to you
rod-router
Re: port fowarding
Port in question is 5006 (the 9308 port has no issues)
Yes, it is synology. I can enter locally and open login via quickconnect too however I need to be able to drag and drop files
Yes, default gateway is set HUB2 address
Not had any issues with my previous ISP
Champnet
Fixes: 21
Re: port fowarding
@rod-router  I've a couple of those boxes I'll have a play tomorrow................
rod-router
Re: port fowarding
Port is now open.
I have a VPN service installed on the synology for further protection and I needed to select a check box named 'accept multiple gateways'
Although I still cannot access my NAS from outside the network, for now back to synology help pages
Thank you all for your help and suggestions Smiley which did spur me on
Champnet
Fixes: 21
Re: port fowarding
@rod-router  Thanks for the update, let us know how you get on...........
rod-router
Re: port fowarding
I managed to get the port forward open however my synology webdav client is not responding for some unknown reason even though everythng is online and seen by their network.
I am now using a workaround a program called Tailscale, its free for persoanl use, uses Google authentification without the need for port forwarding and can access my files anywhere.
Champnet
Fixes: 21
Re: port fowarding
@rod-router  Tailscale, good reccomendation.......
