port forwarding for house alarm
- My Router
- Re: port forwarding for house alarm
17-01-2017 2:29 PM
my alarmfitter was unable to connect my house alarm to my router. if it is connected to my router then when the alarm goes off, i get notified and can control my house alarm from my iphone.
my alarm fitter was told that we cannot do port forwarding using a plusnet router. however, i have been told by plusnet agents that we can do port forwarding but they wont give me any advice over the phone.
the alarm fitter needs to:
enable a tcp port 1001 to device com wifi. this needs to be attached to a 'device/program' on the router. he also needs to reserve an address in dhcp settings.
can all of this be done and how does he do it? thanks
18-01-2017 7:31 PM
If the alarm is active the router won't give it out
Post forwarding can be set up, not on the router at the mo but in the advanced menu there is ability to create a new service tcp port 1001 give it a name and map external to the static ip you use above.
If that doesn't make sense I'll try to grab a screenshot later!
18-01-2017 9:43 PM
21-01-2017 8:46 AM
This should help
https://community.plus.net/t5/Gaming/Plusnet-Routers-and-Port-Forwarding/m-p/1307973#M17456
Same instructions just different post and device to forward too.
- My Router
