no ip address could be provided to my phones and ipad
LaurenB
Fixes: 131
Re: no ip address could be provided to my phones and ipad
Hiya @charlesso, thanks for the update and I am pleased you were able to fix it.
Please get back to us if you have any further queries.
 Lauren Barry
charlesso
My problem haven't fixed really as I only can use 2.4GHz in some devices (I don't know why). Would Plusnet please arrange change my router for the real solution to me?
Fixes: 1,642
Hi @charlesso
I'm really sorry to see you're still having Wi-Fi issues.
Before we replace the router as it may not actually be faulty, what happens when you try to connect your devices onto 5GHz? Do you see a particular error message?
Also, did you try the factory reset, as well as "forgetting" and reconnecting up to the WiFi network on your affected devices?
I'd note that if you do a factory reset then you'll need to separate the 2.4GHz and 5GHz wireless frequencies again.
Let me know how it goes. Smiley
Fixes: 334
Are all your devices capable of a 5GhZ connection? - some older ones may only be 2.4GhZ capable.
charlesso
I have tried to reset the router by all means of method including unplug the power/ reset/ restart it before I learn how to separate two frequency.
charlesso
Yes, all my devices are compatible to 5Ghz connection. No any problem in the first 3 months.
Fixes: 334
@charlesso OK - it was just a thought.
adam945
Fixes: 113
Thanks for getting back to us @charlesso, tho9ugh it's still unclear as to whether you've done a factory reset of the hub. To do this, you'll need to push a pin into the reset hole at the back of the router, and hold it in until the light at the front goes green.
 Adam
 Plusnet Help Team - Leeds
charlesso
Hi Adam,
I tried to reset the router according to your suggestion but it still doesn't work.
TheMightyAJ
Fixes: 126
Thanks for confirming that @charlesso. A thought has occurred to me and I can't see it's been mentioned so far in the thread - Have you made sure all of the affected devices are running on the most up to date version of their firmware/software?
 Alex H
charlesso
I am sorry to let you know that I don't think the software of five to six devices are not up to date in the same time and this problem started in a midnight for those devices which involved i-phone, i-pad, laptop and also android devices.
adam945
Fixes: 113
Thanks a lot for getting back to us @charlesso and I'm sorry to hear that the issues continues. I've just had a look in the account and can see that our Technical Support Team have processed a new router to be sent out. You'll be receiving this within the next 3-5 working days. Smiley
 Adam
