need setup help got Netgear AC1900 D7000V2 and upgraded to fibre package as have FTTC
PSC1989
need setup help got Netgear AC1900 D7000V2 and upgraded to fibre package as have FTTC.
have got the netgear AC1900 D7000V2 which i have had for a couple years now and have recently upgraded to fibre FTTC connection type not fibre to premises and need help as to how it needs setup for FTTC Connection type do i need to change any settings do i need anything do i need to connect anything else to it.
it is currently set up micro filter to dsl connection on netgear AC1900 D7000V2 router and power plug connected and power on do i need to connect anything else to is or alter settings for FTTC connection type.
2 REPLIES 2
Mustrum
Fixes: 75
Re: need setup help got Netgear AC1900 D7000V2 and upgraded to fibre package as have FTTC
If you have any extensions then idealy you will get better speeds with a VDSL filtered master socket.
go to routerlogin.net and log in, and you will need to change Transfer mode to VDSL, and DSL type to VDSL.
The other settings should change automatically if you have it set to UK and ISP as Plusnet or BT.
Just in case, make sure Use VLAN is ticked and set to /
Fixes: 1,480
Moderators Note
This topic has been moved from Fibre to My Router
