my wifi is rejecting certain PC's
Fixes: 480
Re: my wifi is rejecting certain PC's
@Anonymous
So stepping back, how do you know that the PC is connected wirelessly to the hub?
because there is no network cable and I can view my doorbell which only shows on my wifi
@Anonymous wrote:
 is there any way to change the MAC of the pc's connection?
You can locally administer MAC address for most Network cards in a PC, the method is operating system dependant.
A search should provide the answer.
Ok thanks
Fixes: 480
Is this a live view, not just the cached pictures? I’m totally stumped how this can be a live view without the PC being connected to the hub. That is, unless there is an alternative direct connection between the camera and PC. The camera isn’t by any chance connected to its own hub?
