mobile phone 5ghz drop out
hackworth1
frustrating as wifi signal is erratic and the wifi will drop out on my mobile phone, yet my other devices on 2.4ghz range works fine.
is there a way i can switch my phone to the 2.4ghz range?
2 REPLIES 2
Fixes: 1,483
Re: mobile phone 5ghz drop out
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Fixes: 1,483
Navigate in a web browser to 192.168.1.254.
Click Advanced Settings
Enter your Hub admin password when prompted (unless you've changed it, you'll find the default password on the settings card)
Continue to Advanced Settings.
Click on Wireless.
Click 5GHz tab.
Change 'Sync with 2.4Ghz' to No.
Change the name of the 'Wireless SSID' - I added a '_5' on the end.
Save the changes.
You can then select which one you want per device.
