iphone 11 unable to connect to wifi
- My Router
- iphone 11 unable to connect to wifi
16-07-2021 10:06 PM
HI,
Second post in a week....
we have multiple iphones (3) in the house and (iphone 11s) and they have all intermittantly been unable to connect to the wifi,, unable to join network.
tried rebooting the phone, forget networks etc. only thing that fixes it is rebooting router which i dont want to do often....
i've read other posts on splitting signal between 2.4 and 5 but this router does not allow this option.
what with precious errors (too man stas) and now this not a happy start to what should be simple basic broadband!
regards
router is
F@ST2704N |
Re: iphone 11 unable to connect to wifi
16-07-2021 10:48 PM
How long is it since the router was restarted,
17-07-2021 9:43 AM
I understand that there is a limit of 16 devices that can connect to a 2704n. If you are exceeding this number complain to Plusnet and ask for it to be replaced with a Hub One, see https://community.plus.net/t5/My-Router/Is-there-a-12-device-limit-to-connected-devices/m-p/1653014#...
17-07-2021 12:23 PM
Son rebooted router last night but not a solution since the line will be throttled if router keeps getting rebooted
17-07-2021 1:11 PM
17-07-2021 2:07 PM
Probably no more that 6 devices at any one time, given it’s ADSL it can’t really handle many. Whether they are active eg someone using them I don’t know.
Regards
18-07-2021 8:46 AM
Try telling the phone to forget the connection and then connect again.
18-07-2021 11:40 AM
I’m not sure I ever said they were the same issues? I worked for BT for 10 years so have some basic understanding how networks work. Putting that aside…the error is “unable to join the network” , seems the same as an earlier issue with an iPhone 6 in this forum . I’ve changed the ssid and channel, and rebooted which has forced a reconnect. Simply forgetting the network or rebooting the iPhone did not resolve the issue.
I will screenshot it next time it happens
Kind regards
18-07-2021 8:19 PM
On the Wi-Fi settings in the phone, when the device is in this state, what IP address do you see in the network details (press the i).
18-07-2021 8:59 PM
Thread moved from ADSL Broadband to My Router.
Forum Moderator and Customer
- My Router
