intermittent or invisible 5G
addl1bandscore
I've found that when I try to find the 5G wifi from my plunet hub it has either disappeared entirely or is saying that I am using the wrong password (which I am not). If I boot the hub it sometimes reappears for a while and I can log in.
I've noticed a huge thread on this but it remains a problem all this year. What is wrong with 5G
3 REPLIES 3
Fixes: 1,474
Re: intermittent or invisible 5G
Moderators Note
This topic has been moved from ADSL Broadband to My Router
bobpullen
Fixes: 307
Sorry to hear you're having problems.
Would probably have been better to have posted in the larger thread on the subject.
Regardless, I've just pushed an update to your router that should help. You'll need to switch it off/back on at your side to apply the changes.
addl1bandscore
Hi Bob.
thanks for your reply I've done as you suggest and hopefully your update will solve the problem.
thanks again
Keith
