iMac won't connect to Plus One router
- My Router
- iMac won't connect to Plus One router
06-12-2016 11:00 PM - edited 06-12-2016 11:00 PM
I'm a long standing plus net fibre broadband user and have just been sent a new Hub One router which connects fine to all my devices except my iMac which keeps telling me to put in a WPA2 password and then tells me my password is invalid (it's not!)
I spent nearly an hour on the phone to plusnet support earlier this evening and they concluded that this was Apple's problem, not theirs!
I can't believe I'm the first person to experience this problem, has anyone found a workaround please?
i'm running Mac OS X El Capitan btw.
Re: iMac won't connect to Plus One router
07-12-2016 4:11 AM
Have you tried splitting the 2.4 and 5 GHz wifi networks by changing the name of the latter ?
07-12-2016 7:51 AM
It certainly did with the issue we had with MBPs
19-02-2018 11:51 AM
Did you solve the issue? I am experiencing the same thing when I try connecting my MacBook to my daughter's plusnet router when I visit her. All our phones, and windows pcs connect flawlessley, but the Mac just shakes the screen at me and says the key is invalid. But I'm typing the key correctly! SOOOOO frustrating. I even logged into the plusnet router via a windows pc (actually the same MacBook booted off my secondary windows partition). I changed the security settings and key and yet when I try connecting with these different credentials I still get the shaking screen and 'invalid key' error. My Mac just will not behave with PlusNet routers.
03-03-2018 6:48 PM
The solution is described above. Many iProducts has significant issue maintain wifi connectivity when there are both 2.4GHz and 5GHz networks available using the same SSID. It ought not be a problem ,but it is.
06-03-2018 1:45 PM
Splitting the two frequencies apart generally solves a lot of problems especially with Mac's.
Please let us know how you get on.
06-03-2018 6:44 PM
07-03-2018 3:19 PM
- My Router
