hub one no dmz
FIXED- Subscribe to RSS Feed
- My Router
- Re: hub one no dmz
26-02-2017 1:39 PM
i have the new hub one and im trying to get teamspeak 3 server running i have port forward the right ports and even dmz my computer on the hub but its not letting any incoming connection any help would be great ( pulling my hair out over this )
Fixed! Go to the fix.
27-02-2017 8:20 PM
The Plusnet Hub One is basically a re-branded BT Home Hub 5A, there are quite a few anecdotal accounts on the internet of port forwarding being flaky on the Home Hub 5A.
Re: hub one no dmz
28-02-2017 2:44 AM
thank for the replay mikelahey i tryed all day to fix the problem but ended up putting the old box back on and hay presto i got a dmz and all is working fine i hope they sort it out.
pitty the new box is just a cost cutter but thanks for the info
