firmware upgrade request please.
FIXEDTopic Options
- My Router
- Re: firmware upgrade request please.
24-04-2020 9:41 PM
ok so turns out my new super duper router has gone duff.
ive plugged in my old plusnet homehub, please can i have a firmware upgrade?
if the firmware upgrade sorts the wireless issue i had then the superduper can go back to the shop.
my router is on
Plusnet Hub One | Software version 4.7.5.1.83.8.226 | Last updated Unknown
thanks
Fixed! Go to the fix.
Message 1 of 2
(786 Views)
1 REPLY 1
27-04-2020 7:26 PM
Hello @CactusJack,
Can you please PM me the serial number and MAC address from the bottom of the router and I will look into getting this arranged for you.
- My Router
