extend signal from Plusnet 2704n with own Safeguard settings
FIXED- Subscribe to RSS Feed
- My Router
- extend signal from Plusnet 2704n with own Safeguar...
17-08-2018 8:43 PM
Hi, I'm wondering if its possible to
a) extend signal from main router (Plusnet 2704n) to another part of a house (annexe) using a second router
b) if so, does that second router have to be a Plusnet 2704n or would other routers be compatible ?
b) could I have different Safeguard settings for each router ?
c) could/would the second router have a different wifi password to the main router ?
Grateful for any advice, expertise.
Fixed! Go to the fix.
Re: extend signal from Plusnet 2704n with own Safeguard settings
18-08-2018 11:18 AM
You do not want a second router. You do not say whether it is just wireless or Ethernet that you need at the remote location. If it's only wireless then a wireless extender such as this should be good enough for a 2704 n http://www.argos.co.uk/product/1286627?_$ja=tsid:11525%7Cacid:Kelkoo%7Cagid:Technology+%2f+Laptops+a...
18-08-2018 11:38 AM
Hi Baldrick1, Thanks for replying.
Yes, I could just use an extender but its not really extending the signal that's my problem. I want to try and extend the signal to another part of the house so that I can have Safeguard settings on that extended signal that are different to the settings on the main router -- and I don't know if that's even possible.
Thanks,
L
18-08-2018 11:59 AM
Safeguard is applied at the network/DNS layer, not at a device layer, so what you're hoping to achieve isn't possible I'm afraid.
18-08-2018 1:39 PM
Hi Bob,
Yes I was afraid that might be the case -- just wanted confirmation, so thanks for the info.
I need to find a way of only allowing very limited apps and websites to the devices in the annex and parental software doesnt cut it 😕 Maybe Open DNS would be a solution ? I'll see.
- My Router
