ethernet /internet cable hub2
za
want to order a smaller cable to router as provided one is too long and looks unsightly but unable to find the description on the existing one online and need a bit of help and as you can see i'm 81 year old and absolutely hopeless with anything in the modern world so any advice would be most welcome ....za
4 REPLIES 4
za
Re: ethernet /internet cable hub2
sorry just realised i should have said broadband cable
Fixes: 480
@za
The DSL cable that is fitted between the Plusnet hub and the filter is an RJ11, see https://www.amazon.co.uk/rhinocables%C2%AE-Premium-Internet-Broadband-Telephone-White/dp/B01NAYNULL/...
The Ethernet cable that fits in the Yellow sockets is a CAT5e RJ45 like these.  https://www.amazon.co.uk/rhinocables-Cat5e-Ethernet-Speed-Network/dp/B0728GS2VH/ref=sr_1_4?crid=1T60...
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to My Router
za
thanks for your help much appreciated.... za
