err_connection_reset on SOME websites only, All PCs, All Browsers
- My Router
- Re: err_connection_reset on SOME websites only, Al...
04-11-2016 11:07 PM
Been running my Zyxel VMG8924-B10A VDSL router fine without issue with Plusnet FTTC for some time.
Last 2 days something has gone wrong, for certain websites only (eg, bbc, ebay) I will lose access and Chrome reports err_connection_reset 101 - other browsers such as IE and Edge also report similar failure as do other computers via ethernet and mobiles via wifi.
So, it's not a computer, browser or wifi/ethernet specific issue.
If I reboot the router everything returns to normal for a few hours then it will fail again in a similar way.
Note I can both ping and traceroute to the affected websites when the fault occurs, it seems purely a http/https type issue...
I factory reset via the GUI and reloaded my backup config file afterwards but the issue remains.
Anyone come across anything like this before ? I'd like to say the router is failing but the nature of the fault doesn't seem like a hardware problem.
My only thought at the moment is a possible MTU issue but the router is set at 1492 and has never been changed so unless something further down the chain like plusnet routers doesn't like the packets?
Re: err_connection_reset on SOME websites only, All PCs, All Browsers
05-11-2016 9:59 AM - edited 05-11-2016 10:01 AM
This sort of problem is why we always use the router / modem supplied by our ISP, in this case Plusnet.
The link below may help you.
https://appuals.com/best-fix-err_connection_reset/
06-11-2016 7:17 PM
I've tried different MTUs on the router but no difference.
Think I'll look for a different combined VDSL/router combo.
- My Router
