disable wi-fi on router
philip4000
I've just signed up and am awaiting my new router. Does anyone know if the current router supplied by Plusnet has a physical swich to turn off wi-fi? Alternatively can this be done by going to an online control page and disabling it there?
2 REPLIES 2
bill888
Champion
Fixes: 36
Re: disable wi-fi on router
The Hub Zero and Hub One routers supplied by Plusnet do not have a physical wireless on/off switch.
You can indeed log into the router and disable the wifi.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
BenB
Fixes: 20
Hi @philip4000 and welcome to the community forums.
Yeah as per @bill888 comments you will have to log into the router where you can control the wifi connection to be on or off
