cheap Plusnet fibre compatible routers?
- My Router
- Re: cheap Plusnet fibre compatible routers?
02-05-2020 3:25 PM
Looks like I'm going to need to get an alternative router to the Hub One which I can't get to work on LAN with my consoles. I don't need wifi (existing mesh so router wifi will be disabled) so am simply after as simple a router as possible with 4 LAN ports which can be configured to work with Plusnet Fibre. Any suggestions? What features should I be looking for as some of the cheap routers in stores don't seem to have DSL line ports?
02-05-2020 4:36 PM
you say you can't get it to work with the consoles, what issue do you have?
02-05-2020 5:40 PM
03-05-2020 10:28 AM - edited 03-05-2020 10:31 AM
My first recommendation would be a BT Smarthub 6 but I guess the jury might be out whether they have the same problem.
Any third party manufacturer of combined ADSL/VDSL modem/routers should do the job.
Don’t fall into the trap of thinking that all you need is a router, you need the modem bit as well.
03-05-2020 11:24 AM
"Don’t fall into the trap of thinking that all you need is a router, you need the modem bit as well."
Yup, that's why it is quite challenging to find a compatible one online. Smarthub may well be the way to go. Quite why my last Plusnet router worked (but is now recycled) and why the new one doesn't is a mystery.
- My Router
