changing adsl router
- My Router
- changing adsl router
21-07-2017 2:44 PM
I wish to change my Plusnet router for a tp-link Archer 750 ... I should like to know if there are any issues (I am not a techie!)
Re: changing adsl router
21-07-2017 4:21 PM - edited 21-07-2017 4:26 PM
Are you on ADSL or Fibre ?
Ah! must read more carefully , I see you say adsl router.
You need to make sure that the new one is a combined modem/router
I think the C2 model is just a router whereas the D2 model is a modem/router.
If you're going to change it, then you might want to think about future proofing and go for one that is Fibre compatible as well.
There's a good list here http://forum.kitz.co.uk/index.php?topic=14436.0 with details and some reviews
21-07-2017 4:24 PM
Hello... I am on ADSL..
21-07-2017 4:26 PM
Yup , realised that and updated my post.
21-07-2017 4:30 PM
It is a combined modem/router, the chances of Fibre in rural Norfolk is remote in the next few years!!! my best download is 2.4Mbs...
21-07-2017 4:42 PM
In that case there shouldn't be any problems. You will just need to configure it with your PlusNet username and password.
22-07-2017 10:26 AM
Aye, that should be fine. The connection details you'll need can be found here: https://www.plus.net/help/broadband/broadband-connection-settings/
Let us know if you run into any issues.
Anoush
