changing adsl router
ajcleaver
I wish to change my Plusnet router for a tp-link Archer 750   ... I should like to know if there are any issues (I am not a techie!)
6 REPLIES 6
Fixes: 393
Re: changing adsl router
Are you on ADSL or Fibre ?
Ah! must read more carefully , I see you say adsl router.Sad
You need to make sure that the new one is a combined modem/router
I think the C2 model is just a router whereas the D2 model is a modem/router.
If you're going to change it, then you might want to think about future proofing and go for one that is Fibre compatible as well.
There's a good list here http://forum.kitz.co.uk/index.php?topic=14436.0 with details and some reviews
ajcleaver
Hello... I am on ADSL..
Fixes: 393
Yup , realised that and updated my post.
ajcleaver
It is a combined modem/router, the chances of Fibre in rural Norfolk is remote in the next few years!!!  my best download is 2.4Mbs...
Fixes: 393
In that case there shouldn't be any problems. You will just need to configure it with your PlusNet username and password.
Fixes: 1,600
Aye, that should be fine. The connection details you'll need can be found here: https://www.plus.net/help/broadband/broadband-connection-settings/
Let us know if you run into any issues.
Anoush
