change out of asus router to Ubiquity USG - advic eon settings
- My Router
- change out of asus router to Ubiquity USG - advic ...
26-11-2018 1:48 PM
Hi
i'm going to replace my old asus rt66. and move over to a Unifi security gateway, does anybody have any advice on setting up a new USG - eg what are the settings i will need to enter. im using the std openreach modem with it
im on a fixed IP with plusnet, and will need it to serve up DNS services, DHCP server and firewall for my home network , will also need to set up so i can VPN into my homenet
any advice gratefully received
thanks
d
Re: change out of asus router to Ubiquity USG - advic eon settings
27-11-2018 2:17 PM
I found it pretty easy to set up, the hardest part was getting my Draytek Vigor to just be a modem. The key settings are in the WAN settings where you need to set the Connection type to PPPoE and set the credentials. DNS, DHCP, firewalls and even VPN are all pretty straight-forward to set up.
30-11-2018 11:14 PM
many thanks for this , am now set up, was pretty easy and thanks for the PNG.
Only issue i have now is setting up vpn so i can remote in, followed the guide unifi guide for L2TP using radius , and win 10.. unable to connect, done the same on android, still no connection, checked and re-checked
- My Router
