alternative to openreach modem
Ausiemate
My BT Openreach modem is 7 years old and I’m sure it will fail at some point.  As replacements aren't supplied anymore and I don't want a PlusNet hub, as I need to be able to turn wifi off, any suggestions on an alternative hub and/or modem?  Currently using an Asus router and Deco M5 mesh system with my openreach modem
3 REPLIES 3
RichardB
Aspiring Champion
Fixes: 29
Re: alternative to openreach modem
Hi @Ausiemate
I believe you can turn the WiFi off on a Plusnet Hub One.
However, the PN Hub One cannot be configured to modem only mode.
So it will retain its routing mode.
A cheap'ish option is the TP Link TD-W9970 which can be set to modem only mode.
https://www.tp-link.com/uk/support/faq/1332/
Regards
Richard
Ausiemate
@RichardB Thanks for the suggestion will have a look at the TP link.
Strat
Fixes: 522
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 93.0 (64-bit)
