Working: OpenWRT on LinkSys WRT1900AC with BT Huawei Echolife HG612 v3B VDSL Modem
FIXED- Subscribe to RSS Feed
- My Router
- Working: OpenWRT on LinkSys WRT1900AC with BT Huaw...
01-03-2020 5:16 PM
I am posting this both as a reminder to myself, and to help anyone else trying to get this, or a similar combination of hardware, to work.
The hardware I have here is:
- BT Huawei Echolife HG612 v3B VDSL Modem, using the BT-supplied firmware
- LinkSys WRT1900AC v1 router, with OpenWRT v19.07
After much trial and error I have a working VDSL configuration. The '/etc/config/network file' looks a lot like this:
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fdd4:d4d9:c42b::/48'
config interface 'lan'
option type 'bridge'
list ipaddr '<INTERNAL IP>/<NETMASK>'
option ifname 'eth0'
config interface 'wan'
option delegate '0'
option proto 'pppoe'
option username '<YOUR PLUSNET DSL USERNAME>'
option ipv6 'auto'
option password '<YOUR PLUSNET DSL PASSWORD>'
option ifname 'eth1'
config interface 'wan6'
option proto 'dhcpv6'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option vid '1'
option ports '5 3 2 1 0'
config switch_vlan
option vlan '2'
option vid '2'
option ports '6 4'
config switch_vlan
option vlan '3'
option ports '6t 4t'
option vid '101'
In the GUI the Switch and WAN interface are set up as per the attached images.
I will admint to have no clue about whether the switch settings are having any effect, but I can connect to PlusNet VDSL no problem.
Fixed! Go to the fix.
02-03-2020 6:17 AM
Moderators Note
This topic has been moved from Fibre to My Router
Re: Working: OpenWRT on LinkSys WRT1900AC with BT Huawei Echolife HG612 v3B VDSL Modem
03-03-2020 10:02 PM
Update: VLAN ID 101 has been deleted from the Switch configuration, and all is still working.
- My Router
