Wireless network code
emmagar40
My Wireless network code on the back of my new router is different to the one that is appearing on my wifi options on my laptop and phone… meaning the password will not work or log in?
Any help with this?
I have tried searching the Network code on the back of my router but it’s not recognised?
5 REPLIES 5
Shep41
Fixes: 6
Re: Wireless network code
If you have had a new router, the network name will have changed. Select the correctly named network and enter the password and hey presto
emmagar40
I am a new customer so this is my first router with Plusnet.
The named wifi network code that is on my router is completely different to the one that is showing as available on my laptop.
I have tried searching the correct wifi network but it is not valid?
Mustrum
Fixes: 76
Try a factory reset - locate the pinhole on the rear of the router, insert a suitably sized item, paper clip or whatever, keep it pressed for 30 secs - can you now see the Correct ssid/network name?
emmagar40
I have just tried this and no luck! Thank you for your suggestions!
adam945
Fixes: 113
Good morning @emmagar40
Sorry to hear that you're having problems with the router. When you can, please send me a PM with the serial number that's on your router, I'll check to make sure it's the same on our end, if not, I'll send a new router out.
 Adam
 Plusnet Help Team - Leeds
