Wireless network code
- My Router
- Wireless network code
28-06-2021 9:26 PM
Any help with this?
I have tried searching the Network code on the back of my router but it’s not recognised?
Re: Wireless network code
28-06-2021 9:33 PM
28-06-2021 9:38 PM
The named wifi network code that is on my router is completely different to the one that is showing as available on my laptop.
I have tried searching the correct wifi network but it is not valid?
28-06-2021 9:55 PM
Try a factory reset - locate the pinhole on the rear of the router, insert a suitably sized item, paper clip or whatever, keep it pressed for 30 secs - can you now see the Correct ssid/network name?
28-06-2021 10:09 PM
29-06-2021 11:34 AM
Good morning @emmagar40
Sorry to hear that you're having problems with the router. When you can, please send me a PM with the serial number that's on your router, I'll check to make sure it's the same on our end, if not, I'll send a new router out.
