Will i need a new plusnet router for full fibre.
wufer
I am getting Full Fibre on 19 June.
At the moment I have a Plusnet Hub Two for my broadband and phone.
Can I use my Hub Two for Full Fibre, or do I need a Plusnet Full Fibre router.
If I do need a Plusnet Full Fibre router, how do I order one.
Cheers.
Edit.
My question has been answered.
Thank you both.
4 REPLIES 4
Fixes: 579
Re: Will i need a new plusnet router for full fibre.
@wufer
Yes, the Hub 2 is the router supplied for full fibre.
In your case you just disconnect the DSL cable and connect from the WAN (red) port to the ONT using an Ethernet cable.
NB the ethernet cable should be cat5e or better
Fixes: 382
@wufer The Hub2 is already FF  capable, and does not need any replacing - just a bit of cable switching.
Ian06
Fixes: 6
You might also find this info helpful .... Hub 2 set up for Full Fibre
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to My Router
