Will fibre router work with ADSL?
- My Router
- Will fibre router work with ADSL?
15-08-2017 8:41 PM
Hi. I have upgraded to fibre from ADSL with Plusnet. My fibre router has arrived but my connection date is next week. Can I plug in my fibre router now? Will it work with the current ADSL? Will it mess up the fibre upgrade?
Message 1 of 2
(907 Views)
1 REPLY 1
Re: Will fibre router work with ADSL?
15-08-2017 8:49 PM
Yep that should work with ADSL. If you set up your new router before your fibre goes live then I’d expect just a short break in service on the day of the upgrade whilst the work is being completed then you should be on fibre.
Anoush
Anoush
Message 2 of 2
(900 Views)
- My Router
