Wifi signal keeps dropping
- My Router
- Wifi signal keeps dropping
18-06-2020 4:51 PM
Hi, I moved to Plusnet from BT in Feb 2020. Never had any problems with my BT wifi ever. On connecting my new Plusnet router I have had continuous ongoing problems with the Wifi dropping to the point where it becomes unusable. My wife and I are retired so rely heavily on our Wifi. I raised a ticket which resulted in some diagnostic tests but no real improvement. I have spent hours and hours going through every self-help suggestion. I have moved the router to be plugged into the master socket with no change. Tried different channels etc but nothing has worked. Having just done a test, my download speed is about 60mps and my upload is about 9mps yet it freezes or drops out for a minute or two. Resetting the router seems to work for up to an hour then it reverts back. I am not a very technical person but It feels to me like a faulty router? Can anyone help me to get this resolved please? Thank you
Re: Wifi signal keeps dropping
18-06-2020 4:54 PM - edited 18-06-2020 4:55 PM
This topic has been moved from ADSL Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 100.0.1 (64-bit (64-bit)
20-06-2020 7:59 PM
I have seen speed issues with laptops and outdated drivers.
If you have a laptop, have you tried getting a long network cat5e cable and using that for a while to see if it is your router of wifi causing issues?
22-06-2020 11:29 AM
Thank you for your help.
I have a Macbook, 2 ipads and 2 iphones and a Nest thermostat. There is just my wife and I so all devices are not using Wifi simultaneously. We haven't increased our number of devices since we switched over to Plusnet and we didn't experience these problems before, everything worked fine.
22-06-2020 12:51 PM
If you still have your BT Hub then use that. Setting instructions are here. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
They are better devices then the Plusnet offerings and many of us use them.
22-06-2020 2:35 PM
Thank you Baldrick, I had to send the router back to BT but I will go online and order a second hand one. Thanks for the link for setting it up.
