Wifi keeps dropping out
brassmonkey001
Hi all, new Plusnet customer here.
Since we moved in in December, we have had trouble with the wifi dropping out and devices either keep reconnecting or not connecting for a while.
Plusnet identified a fault on the line to the house and sent an Openreach engineer who replaced the wire from the pole to the house and fitted a new socket. This seemed to fix the line fault but we're still having wifi connection issues.
My Android phone switches between wifi and 4G, my partner's iphone & ipad disconnect and tonight wouldn't reconnect and it said the password was wrong, but later connected with the same password.
I thought it might be the construction of the house causing problems so I bought a Devolo Magic 2 wifi thing to try and improve things. It hasn't. My wifi still keeps dropping out.
Any ideas what's going wrong?
Devices connecting over wifi:
Android phone
Iphone
Ipad
Nintendo Switch
Laptop
Amazon Echo
8 REPLIES 8
RandallFlagg
Fixes: 75
Re: Wifi keeps dropping out
Hi @brassmonkey001
Thanks for getting in touch. I'm sorry to hear you're experiencing wifi dropouts - just to confirm, I've tested your line and it seem unaffected by any external drops/faults, so I agree this seems specific to your wifi connection.
Have you had the opportunity to split out the wifi frequencies on your router as per the info here?
Having a look at the above, in addition to checking out the general wifi troubleshooting here and acquiring a wifi analyzer app on your smartphone/tablet should help make a difference.
Let us know how you get on.
Best wishes
Dave
bobpullen
Fixes: 315
@brassmonkey001, I've pushed the latest firmware build to your router to rule that out as a potential cause.
RandallFlagg
Fixes: 75
Thanks for that, @bobpullen!
brassmonkey001
Thanks Dave,
I've split them now thanks to your suggestion.
I have an analyzer app on my phone so I'll see how things go.
brassmonkey001
Thanks Bob, do I need to do anything?
brassmonkey001
Wifi still dropping out. Any more suggestions?
Fixes: 1,596
Sorry that you're still having WiFi issues.
I don't think there's anything more we could suggest to be honest that we haven't already, so I've RMA'd your router. You'll receive a replacement within the next few days, let us know how it goes once you've received it.
bobpullen
Fixes: 315
Please keep us updated, because it would be unusual for the wi-fi radios to have been at fault.
