Wifi keeps dropping out and router restart only works for a while
- My Router
- Wifi keeps dropping out and router restart only wo...
04-05-2020 5:51 PM
so far today i have refreshed my wifi settings several times and rebooted my router 3 times and each time the wifi signal comes back but then after a while it suddenly degrades to intermitent and then nothing at all. It sometimes shows in the devices as being present with good signal but if i try to connect to it i get a bad password error. my two iPhones seem more sensitive to the issue than my windows laptop but after a while all 3 devices lose the wifi all together. The wired connection to my desktop PC seems to still work.
WIFI comes back when i restart the router and sometimes comes back after just clicking refrsh in the wifi settings but it then goes again after a random period
Could my router be failing because of its age? (about 3 years old)
Re: Wifi keeps dropping out and router restart only works for a while
05-05-2020 4:32 PM
Hi @halfmanhalfbike, I am very sorry to hear of the issues that you're having with your WiFi.
It sounds like you may be experiencing an issue with the 5GHz wireless frequency as outlined in the thread here.
I have provided some steps on how to separate the 2.4GHz and 5GHz on your account here for you.
- My Router
