Wifi connection issues. Firmware update?
- My Router
- Re: Wifi connection issues. Firmware update?
- « Previous
- Next »
12-03-2019 2:13 PM
Hi @joep, I've just put through a request for you to get that done ASAP.
12-03-2019 2:53 PM
Thanks @adamwalker !
12-03-2019 3:03 PM
15-03-2019 5:53 PM
@joep, yours has been upgraded.
@midlandmike, try a factory reset as I'm struggling to communicate with your hub at the moment. All being well you should then see the new firmware come through in a day or two.
@Gary_Howlett wrote:
I've been on 4.7.5.1.83.8.263 since 27/02/2019 according to my router and I've been having to reset it often since due to not being able to connect to WiFi.
Have the 5 / 2.4 on separate ssid's
Doe the onset of the problem coincide with the firmware update?
If so, is it the 5GHz or 2.4GHz radio you're having problems with (or both)?
- « Previous
- Next »
- My Router
