Wifi checkboxes TG582n
FIXED- Subscribe to RSS Feed
- My Router
- Wifi checkboxes TG582n
06-02-2018 11:23 AM - edited 06-02-2018 11:27 AM
On the TG582n, what is the difference in function between WLAN Enable checkbox and Interface Enabled checkbox? I have done quite a bit of googling on the matter but no page I have seen even acknowledges the presence of both checkboxes on the same router. Some pages mention one and some the other - same with their screenshots! Not seen anyone with exactly my menu
Fixed! Go to the fix.
Re: Wifi checkboxes TG582n
08-02-2018 2:43 AM
Interface is for the wireless connection itself.
Quite obvious when you think about it logically.
08-02-2018 9:35 AM
That's the problem, that bit is obvious and you've told me the obvious bit. I was hoping for more detail about consequences. "Affects the local network", yes, but in what way? What effect? As in, if I leave the interface box ticked, and turn off the other box, does the modem go on pulsing out wifi scans but uselessly because nothing can connect? And if vice versa does it mean for example my tablet can connect to the modem but not get any further like onto the internet?
08-02-2018 11:23 PM
Switching those two options around from the first case scenario will simply result in disabling the wifi from working altogether.
I've no idea why the first option is available in the GUI, it serves zero purpose for most users.
09-02-2018 9:34 AM
Somewhat as I suspected, but I thought it wouldn't hurt to make sure
