Wifi Issue since new router
RedSquirrel
Hi
Since being sent a new router I have had issues with the wifi disconnecting or not allowing me to connect.
I have changed channels, un-synced 2.5 and 5 GHz.
I have attached screenshots as I know there is an issue but cannot solve it currently.
Any help would be gratefully received.
RS
4 REPLIES 4
Gel
Aspiring Champion
Fixes: 27
Re: Wifi Issue since new router
Have you given the 2 channels different SSID's?Huh
Try switching 2.4ghz one off to see if that assists.
Use a wifi analyser to see least used channels in your locale eg inSSIDer.
RedSquirrel
Hi Gel
Thanks for your reply,
I have separated the two frequencies and rename them (SKY  and SKY-5GHZ).
Need the 2.4ghz for my wifi printer.
Still having issues with other client devices in house.
No sure what to try next?
Cheers
RS
11:22:06, 14 Oct. ath00: STA 8c:8e:f2:25:d5:7f IEEE 802.11: Client associated
11:21:33, 14 Oct. ath00: STA c8:85:50:02:d6:5c IEEE 802.11: Client disassociated
11:21:18, 14 Oct. ath00: STA 80:e6:50:76:13:8e IEEE 802.11: Client disassociated
11:21:17, 14 Oct. ath00: STA 80:e6:50:76:13:8e IEEE 802.11: Client associated
11:21:14, 14 Oct. ath00: STA 80:e6:50:76:13:8e IEEE 802.11: Client disassociated
11:21:12, 14 Oct. ath00: STA c8:85:50:02:d6:5c IEEE 802.11: Client associated
11:19:27, 14 Oct. ath00: STA d0:25:98:18:8c:e8 IEEE 802.11: Client associated
11:19:27, 14 Oct. ath00: STA d0:25:98:18:8c:e8 IEEE 802.11: Client disassociated
11:18:52, 14 Oct. ath00: STA 8c:8e:f2:25:d5:7f IEEE 802.11: Client disassociated
11:18:50, 14 Oct. ath00: STA c8:85:50:02:d6:5c IEEE 802.11: Client disassociated
11:18:39, 14 Oct. ath00: STA 8c:8e:f2:25:d5:7f IEEE 802.11: Client associated
11:18:32, 14 Oct. ath00: STA c8:85:50:02:d6:5c IEEE 802.11: Client associated
11:16:28, 14 Oct. ath00: STA 8c:8e:f2:25:d5:7f IEEE 802.11: Client disassociated
11:15:58, 14 Oct. ath00: STA 8c:8e:f2:25:d5:7f IEEE 802.11: Client associated
11:15:31, 14 Oct. ath00: STA 8c:8e:f2:25:d5:7f IEEE 802.11: Client disassociated
11:14:40, 14 Oct. ath00: STA 8c:8e:f2:25:d5:7f IEEE 802.11: Client associated
11:13:54, 14 Oct. ath00: STA c8:85:50:02:d6:5c IEEE 802.11: Client disassociated
11:13:47, 14 Oct. ath00: STA c8:85:50:02:d6:5c IEEE 802.11: Client associated
11:11:24, 14 Oct. ath00: STA c8:85:50:02:d6:5c IEEE 802.11: Client disassociated
Moderator's note by Mike (Mav): Post released from Spam Filter and near-duplicate post removed.
MatthewWheeler
Fixes: 456
Sorry to hear you're having issues.
Have you tried forgetting the network and rejoining it when it's not allowing you to connect?
 Matthew Wheeler
terumikami
We have the same problem, but now I discovered the root of the problem. If you are connecting to a wifi with weak signal, or a wifi with many devices connected, then it is the cause. Whenever I tried playing games with a wifi with weak signal and many devices connected, it keeps disconnecting and connecting because our phone might too weak to accept wifi signal.
