Wifi Dropping/ extreme periods of high ping
- My Router
- Wifi Dropping/ extreme periods of high ping
15-06-2018 10:10 PM
Every day i get random drops in wifi, checked the log and its usualy like this -
ath00: STA b8:53:ac:20:2c:b6 IEEE 802.11: WiFi registration failed
ath00: STA b8:53:ac:20:2c:b6 IEEE 802.11: Client disassociated
There's also the periods of extreme ping usually once/twice every hour.
Also, my router is located right underneath my room and when connected to my phone etc it has lengthy periods of being connected but no internet access. This usually happens every 5 minutes.
Plusnet routers so far seem shocking.
Re: Wifi Dropping/ extreme periods of high ping
16-06-2018 1:18 PM
Sorry to hear you're having issues.
Have you tried following the steps here to see if that improves things?
16-06-2018 2:47 PM - edited 16-06-2018 3:00 PM
Yes ,i have changed the channel several times with no viable difference.
A WiFi extender seems highly pointless in a room where the router is less than 3 metres away.
17-06-2018 11:21 AM
Sorry to hear this @ant0bot123.
Please can you provide the following information so we can see how best to help you.
Do this issue occur on a wired connection also?
What router do you have ?
Does the router Lights change colour when it drops?
17-06-2018 11:40 PM
This issue does occur with when on wired
The router is the default issued by plus-net ( hub)
The router goes orange for several seconds then goes back to blue.
18-06-2018 1:07 PM - edited 18-06-2018 1:09 PM
Hi @ant0bot123
Thank you for confirming that this issue is occurring over wired connections too and that the light on your router changes colour when your connection drops.
I've tested your line today however the test is not picking up any issues:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 80.0 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 444.7 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2018-06-05T13:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 79.9 Mbps | 79.9 Mbps | 79.9 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 792.0 Sec | 900.0 Sec | 899.5 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-06-18T12:32:17.694+01:00 | 2018-06-18T12:47:17.694+01:00 |
Ingress Code Violation | 0 | 2 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
The connection log is showing that there have been two drops in the last eight days, which would be classed as normal behaviour for the line.
Are the drops that you are seeing on wired connections more frequent than this? If so, please report the issue here and let us know when you've completed it.
- My Router
