Wifi Discs
- My Router
- Re: Wifi Discs
Wifi Discs
27-11-2020 10:28 AM
I have been looking at the BT Mini Wifi Discs and am trying to find out if they will work with Plusnet. We have a Hub One with Unlimited Fibre. Has anyone tried them and do they work well (I'm looking at the 3-pack).
We have a problem with connection being weak/flakey at the back of the house and I thought these might help. Doesn't seem to be any option to 'Chat' with someone and I don't want to call when it's not urgent.
Thanks.
Re: Wifi Discs
27-11-2020 2:24 PM
A mate has these and while they gave a great improvement on wifi coverage the speed he gets is really poor.
Re: Wifi Discs
27-11-2020 2:40 PM
Re: Wifi Discs
27-11-2020 3:29 PM
Re: Wifi Discs
27-11-2020 3:30 PM
Moderators Note
This topic has been moved from Fibre to My Router
Re: Wifi Discs
27-11-2020 4:16 PM
Re: Wifi Discs
27-11-2020 4:21 PM
What is the construction of the walls? You might need to think about placement before ordering any.
Re: Wifi Discs
27-11-2020 4:36 PM
Re: Wifi Discs
29-11-2020 2:08 PM
@janeybeans sorry, I meant to reply sooner.
The speed he gets connected to the discs is slower than speeds when connected to the router wifi.
However, there are parts of his house where the router wifi just doesn't reach - which is the point of the discs.
There are other solutions but at £74 for 3 the mini wifi discs seem OK.
