Wifi Access control loop
Techo
Hello everyone,
Ive tried using the control access feature using by accessing the router via http://192.168.1.254, however once I put anything in the list, I cannot delete it, as it goes into the loop of redirecting me to the login page. In short, I press delete, then it the browser for a brief second says, the page is not working and then redirects me to the login page without deleting the rule, even though I am already logged in. However when I change something in other sections, i do not get this issue. Any suggestions?
Thank you for your answers.
1 REPLY 1
Fixes: 367
Re: Wifi Access control loop
Do a factory reset on the router by inserting a paperclip in to the apprpriate hole on the router. Keep the switch depressed for at least 20 seconds. Then set the router up from scratch.
