WiFi won’t connect on+ off and WiFi slow often
- My Router
- WiFi won’t connect on+ off and WiFi slow often
07-09-2020 8:36 AM
Re: WiFi won’t connect on+ off and WiFi slow often
07-09-2020 9:07 AM
It sounds like your broadband connection is OK but you have a wifi problem, hence the Plusnet response. Starting from the beginning can you advise which Plusnet Hub you have so that we can give further advice. I expect that a Mod will move this post to the more appropriate board.
07-09-2020 10:41 AM
As @Baldrick1 says, really need to know what router you have before you can go much further. It might be your laptop is set for 5Ghz and you don't have that band set up for use. It could even be something simple as log in details. First thing I would do is check what sort of speeds you are getting at the master test socket via a wired connection (bearing in mind the slow speeds mentioned). If that is as expected then time to move onto the WiFi.
As for son saying internet is slow, depends on what sort of incoming speeds you have and what is happening at the time. If you don't know what sort of speeds you should have, go to here (BT wholesale).
07-09-2020 3:33 PM
This topic has been moved from General Chat to My Router.
07-09-2020 3:56 PM
07-09-2020 4:16 PM
07-09-2020 4:27 PM
The Hub Zero WiFi is pretty dire but it should at least connect. What speed should you be getting? See https://www.broadbandchecker.btwholesale.com/#/ADSL
Have you tried moving closer to the Hub. Note that this Hub only works on the 2.4 GHz band and is very bad at handling downloads if something else is uploading at the same time.
07-09-2020 4:51 PM
No one was else was doing downloads at same time and yes I was right beside hub too when it wouldn’t connect before.
- My Router
